The ski went into LIMP mode you have a problem somewhere, the computer inhibits the ignition timing to about 1/2 speed when a problem is detected! when you restart the ski it will reset the computer and run ok until it detects the problem again! You need to have it checked, unfortunately POLARIS dealerships are vey limited on what they are able to do on PWCs as they are no longer required to work on them!!
