1999 slth ignition update kit - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 04-24-2009, 07:34 PM   #1 (permalink)
Default 1999 slth ignition update kit
I am about to install an ignition update kit on my 1999 Polari slth.
I read the instructions, and at the end they state to disconnect a ground wire between the electrical box and the battery. The jetski is not at home right now, so I can look at the battery to see the ground wire.
Is there only one wire on the negative battery terminal? How will know which wire to disconnect?
If anyone has installed the iginition update kit, I would greatly appreciate any information or lessons-learned that will help me install the update kit.
rbdesse is offline   Reply With Quote
Old 05-06-2009, 11:16 AM   #2 (permalink)
Default Update kit installed
Nobody posted a reply to my note, but here is an update. I sucessfully installed the ignition update kit in my jetski, replaced the starter, and replaced everything except the terminal board in my electrical box. The jet ski fired-up on first crank and runs great. The ski has never started so easily since I purcashed it. I think the electric system has been the source of my hard starting, failure to start when hot, and poor idling porformance all along.
Old 06-22-2009, 09:21 AM   #3 (permalink)
Now that you have installed the upgraded ingnition kit, do you have any advice?
What was the name of your kit and where did you get it from?
Thanks!
Dean
europe50 is offline   Reply With Quote
