Spark plugs wrong heat, air leak after carbs, too lean of jetting, wrong mixture jet setting, crankcase seal leak, wrong timing, overheating, excessive carbon buildup. Without oil you usually seize the rings to the cylinder wall leaving aluminum behind.
