Yes Shawn - heat range DOES matter - but that has nothing to do with your problem. I think you proved that yourself since you replaced the plugs and the problem is now back
. The 6's you had DEFINITELY were too hot for your engine regardless. R U sure you cleaned and re-assembled the carbs correctly? Any obstructions in the air intake? Had the machine sat for a while?
