I just started having the same basic trouble with my '97 Polaris SLT H, it's hard to crank and when it does, you've got to squeeze the trigger quickly and repetitively to get it up to hi rpm, then it will go 47mph with my fat ass on it. When you slow down it will cut off, then you have to choke it to get it to fire, then unchoke it to start it again.
I'll try the Seafoam, where can you get that? Walmart? Autoparts store? Any other possibilities? Does this model have separate low & high rpm carb jets, and maybe the low jet got clogged? Any hope to change that out myself if I have basic mechanic skills, if the seafoam doesn't work? Can you even get these parts any more for an old Polaris?
If it dies, what's the best new jetski to get? Need it to pull up a 225lb fat guy on a wakeboard.
thanks!
