wide open
I would over haul the carburetor's (completely) w/carb. kit, check and clean all ports and passages, make sure jets (main & pilot) are very clean and you can see through them. Replace all intake gaskets and double check your high and low speed screws for proper adjustment, make sure all carb. linkage is set correctly and nothing binding. Good Luck
