Genesis I Backfiring???
I have a 2002 Polaris Genesis I with only 72 hours that I just bought. It is my first pwc so please pardon my ignorance. Yesterday I tried to start it and found the battery to be very weak and wouldnt take a charge, so I replaced it. After replacing the battery I tried to start it and when I did it turned over for probably 15 to 20 seconds without starting. I then pulled a plug wire to check for spark and it was firing good. thinking maybe it wasnt getting fuel, I poured a small amount of premix fuel in the carbs or throttle bodies and tried it again. WHen it finally started it ran for just a few seconds and then backfired so hard that it blew off the exhaust hose! I continued trying to start it and almost everytime it backfired. It backfired louder than any backfire I've ever heard. I put it back together as I didn't want to do any damage and thought I would try to research it and see if anyone else has had the same problem. Any thoughts/help would be greatly appreciated. Thanks
