2nd Question on '97 Polaris
Thanks for the excellent info. The jet ski is at the lake, so as we get ready to winterize, we will check these items.
Info: We didn't get the control box completely dry because we couldn't open the spark coils. Currently the jet ski will run fine for a min., then stop running. It will start and run fine for a variable amount of time. After warmed up (> 5 min.), you may get up to 5 mins of good running then it will die. When it dies, you can hit the starter within a 1/4 sec, and the jet ski will start and run fine for another 1 to 5 mins. This condition seems to be worst if you drive the jet at near fill throttle instead of mid throttle. The water separate does not have any water in it. This seems to be a ignition problem, but I'm not certain, so looking for advice/someone's experience. For the first 5 times out after the problem started, the engine would run on 1 cylinder. Now it won't, so I haven't been able to put a ignition light on the spark plug wires to verify the problem.
Thanks!
