'95 650 SL -- Strange starting problem
I'm a decent backyard mechanic, but this problem has me stumped... Was riding the jet ski last weekend, had run for an hour or so and it was running like a champ. Had it at low throttle and the engine just died. Had to get a tow back to shore since it wouldn't start.
It has a new battery. It has spark on all three cylinders. Compression checked on all cylinders, and all equal. Spark plugs are clean and gapped. Fuel pump is pulling gas. Choke is working. Full of new gas and oil. I've tried squirting starting fluid directly into cylinders, pouring new premium fuel diirectly into fuel line, and get the same result... it just cranks and cranks and won't fire.
I haven't checked timing, but the cranking sounds ok.
Please. Any suggestions welcomed!
