Help with a 95 Polaris xls 780
I was given a 95 polaris slx this weekend. Of course when I got it in the garage it would not start. I changed the spark plugs, fuel, oil and got a new battery for it and it would not get a spark. It turned out the kill switch was stuck so i took it apart cleaned it up and the ski fired right up. Thought it was my lucky day!
However, I took it out to the lake yesterday to see if it would run on the water. The ski fires up and sounds great.......... BUT..... When I push on the accelerator the ski does not move an inch. While running the ski it smokes from the impeller and just will not go. So I put the ski back on the trailor and took the seat off to see what it may be. I fired the ski back up and looked down the impeller while my buddy hit the accelerator and it does not spin. Looked down at the engine and the drive shaft seems to be moving but very slow. I'm not sure how to change a drive shaft or if that is the problem. I don't want to waste money on a driveshaft if that is not the problem. Any suggestions or feedback???
This is my first jetski to own... So first time working on one!
