1996 SLT terminal board help! - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 07-06-2011, 08:20 AM   #1 (permalink)
Default 1996 SLT terminal board help!
Anybody have a picture of where all the wires are supposed to go, i stupidly pulled out the board cause there was some major corrosion. I cleaned everything and started to put wires back as labeled on the board, i seem to have extra wires, green ones, and a orange bridge. I bought the clymer manual hoping there would be a picture of the board and where everything went, but it didnt have it. If anybody could help me out that would be great.
Last question is, one of the terminals corroded and pulled out, can i just electrical tape it so it doesnt interfere with the other connections?
robeastunder is offline   Reply With Quote
Old 07-28-2011, 10:32 PM   #2 (permalink)
hay if I have a 96 also the green is the tach if you dont have one tape it and tuck it away.the broken terminal one find the same color that is on the block next to it and splice them and tape them.the bridge im not sure i would have to open mine and look.Good Luck.
viglanti is offline   Reply With Quote
Old 07-29-2011, 08:02 AM   #3 (permalink)
Default Thanks
I will give that a try for sure, i also ran into a popped middle piston which im assuming may have been a result of the corroded terminal board. So i bought a new board and am rebuilding the middle piston. What would really really help is if you could take a good close picture of your terminal board, that i way i can use it as reference. Thanks for all your help, I really appreciate it.
