another no spark issue - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 08-08-2011, 04:43 PM   #1 (permalink)
DBD
Default another no spark issue
I recently inherited a 2000 slh with no spark at the plug.It had a new stator installed as well as a new spark coil.When cranking the stator output read 146-152 ohms and 1.68 volts. When I ran a test on the CDI output to the coil as suggested on this forum I had less than 2 volts out of the CDI when cranking.
Any help on testing the CDI you folks can suggest would be much appreciated
DBD is offline   Reply With Quote
Old 08-08-2011, 11:17 PM   #2 (permalink)
have you checked the shut down switch on the handle bars?
killer454 is offline   Reply With Quote
Old 08-09-2011, 06:32 PM   #3 (permalink)
DBD
The shut down swith seems fine.The engine cranks,I have 12 volts coming into the CDI when cranking but only 2 volts on the output to the coil> I suspect the CDI is bad but read that they are fairly reliable. Is there any way to run a diagnostic on the CDI when it's removed? Anybody?
