SL650 #1 Not running - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 08-23-2011, 06:23 PM   #1 (permalink)
Default SL650 #1 Not running
Got a weird problem that has me pulling hair out
Have a 93 SL650 that doesn't run on #1 (mag) cylinder.
Mechanical : Compression is 150 on #1, 150 on #2, 145 on #3. Did case pressure test today and held 10psi for over 10 min. Checked crank index and runout. 120deg across the board, and .0014 runout.
Fuel : Carbs all check out fine, and squirting fuel in #1 carb bore doesn't make cylinder fire. Fuel flow and pressure to each carb identical. Reeds check out fine for condition and visual seal, but are original reeds.
Ignition : Spark will jump 30kv gap on all three cyl (1/2"). New BR9EIX spark plugs, and have been swapped cylinder to cylinder as well as wires.
All my knowledge says this engine should run great.
Little history : Engine was rebuilt approx 10 tanks fuel ago, and triple outlet fuel pump added at that time. Last summer son burnt #3 cylinder (PTO) running lean when he run tank dry at full throttle. Changed cylinder, piston, and rings, and ran great for three tanks after that. Pulled it out of the water, running fine. Two weeks later put it back in water, runs on center and pto cylinder only.
Engine gives a tiny little extra kick if pull plug wire then reattach, but only for a split second.
Any ideas? I feel I am having major brain fart here
doggercdn is offline   Reply With Quote
Old 08-23-2011, 08:54 PM   #2 (permalink)
Is Your engine reaching full rpm or 5000 only. Also does your fuel valve have a reserve pos.?
Old 08-23-2011, 09:03 PM   #3 (permalink)
Has a reserve position, and only reaches much reduced rpm in water
Old 08-23-2011, 09:42 PM   #4 (permalink)
What does it Rev to out of water? Some Polaris modelshave limp mode which will stumble ignition
Also there is a fuel line routing update that t fuel in from center instead of having to go through 3 then2. To get to one. New boysen power reeds will wake that thing up if you get it fueling
Old 08-23-2011, 10:24 PM   #5 (permalink)
Did fuel line rerouting when engine rebuilt. Revs out past where I'm comfortable revving it out of water.
It doesn't ignition stumble or miss. #1 just doesn't contribute anything to engine. Dead just like blown piston or dead plug. Looked in cylinder with borescope camera and everything is perfect and matches #2 and #3
Old 08-24-2011, 09:18 AM   #6 (permalink)
wow, sounds like you have a gremlin in your ski. good luck.
Old 09-04-2011, 10:29 PM   #7 (permalink)
spark/fuel air/compression
start at spark now
killer454 is offline   Reply With Quote
