2001 Polaris Virage Carb
I have a 2001 Polaris Virage a coupe of years ago I ran into a problem where the craft idle was fine but when you gave it the gas it might go for a while and then bog down.....a guy repaired it said it had something to do with the carb (some internal part that can't be fixed).....I found a brand new carb about $600.....we replaced it worked fine for 2 years......but now it is doing the same thing....rather than spend an additional $600 every two years to replace the carb......is there any other cheaper and/or more permanent fix? If anybody has any suggestions please let me know
