FOR SALE:
Jettrax 100D Double PWC Lift Rack
94” Long for Full Size Trucks With 8' Bed
Holds 2 PWC's up to 48 “ wide and 131" Long
Includes Adapter Kit for newer trucks with high bed sides
Below is the info from the Jettrax Website:
The Jet Trax Rack is the answer to all your problems. How do I tow my boat or travel trailer and still take my Personal Watercraft. The Jet Trax Personal Watercraft Lift offers a unique way to transport your Personal Watercraft in the back of your short or long bed pickup truck. Its "above the bed rail" design allows you to load 2 Personal watercraft and still have almost your entire truck bed available for storing your gear. The Jet Trax attaches securely to the frame of your truck and is easily removable in minutes.
Simply float your Personal Watercraft up to the cradle and tie down the front. Then, press the button to load in approximately 30 seconds. To unload, pull back on the track to start the motion and let gravity and the controlled reverse action of the winch lower your PWC to the water.
What are some of the many benefits of the Jet Trax?
You can carry two Personal Watercraft's on the truck
Pull a boat or travel trailer while carrying two PWC's
Use the bed space to store gear or cargo
Install the rack in minutes by yourself.
Remove the rack from your truck in minutes
No Trailer to Store
No Insurance
No 55 MPH in the slow lane
No Trailer Registration
Some of Jet Trax Features
Precision jig welded utilizing tooled fixtures. Jet Trax is made from 1/8 inch thick, high quality carbon steel providing maximum strength and durability.
Completely Powder coated to hold up under the harshest of weather conditions and tolerates heat and moisture much better than paint. Powder- coating gives much longer wear, is chip and rust resistant, and looks great!
Jet Trax uses maintenance-free HMW nylon rollers. No lubrication is required
Comes with 1 or 2 All Weather 12v 2500 pound electric WARN winch (lifetime warranty on the mechanics of the winch) and 12 foot cable remote control switch.
Attached to your truck with a .5" X 3 " X 48" flat steel mounting plate. This is mounted to the frame of your truck. The Jet Trax thread bolts into the mounting plate. Therefore, you never have to climb under the truck to remove the Jet Trax from your truck.
Jet Trax can be removed from your truck in about 10 minutes.
The Jet Track rests on the floor of the truck bed, not on the bed rails, providing more stability and evenly distributed weight. This feature prevents damage to the bedrails .
Here is a link to the FAQ Page:
Frequently Asked Questions - Jettrax
Here is a link to the brochure:
http://www.jettrax.com/pdf/newbrochure.pdf
Asking $1800/OBO. Includes dual winches with remote, custom caster kits to wheel it around in and out of your garage or shop, battery with battery box.
Q: Will this fit the newer trucks with high bed sides?
A: Yes. I paid Jettrax to upgrade this unit for all of the newer trucks. I have a new Silverado Duramax 3500 and it fits great.
Q: Does it have caster wheel upgrade to roll it around?
A: Yes. They pin together at the base on all four corners. One person can roll it around easily even with two PWC on it.
