JS300 has spark, compression, but... IDK about fuel. HELP!!!
Alright... I recently replaced the cylinder on my JS300 only to find out the head gasket on the new cylinder was blown. OK... replaced the head gasket, reconnected all the hoses, poured a little fuel in the carb, and she fired up. I let it idle for about 30secs, then worked the throttle a bit, let it return to idle, and then hit the kill switch.
Now... I can't get it to start again! (Literally, 30sec later.) I am 100% positive I have spark and compression. But it seems to me that it might not be getting fuel... although I have poured WAY more than enough fuel down the carb.
Should I pull the carb and clean it up or is there another possible remedy?
Thanks,
"Stand up or get off the water..."
