1995 Seadoo xp
Hello, new to forum. Im looking at a 95 sedaoo xp for my daughter. She is 13yrs old and has been wanting a jetski for sometime. I found one thats in good shape cosmetically, but the owner says it runs fine when run on a garden hose on the trailer (engine not under a load). He said when he run the jet ski in the water (engine actually under a load) that it would "pop" back thru the carbs and not run properly. Runs as if the timing is off, he said compression was good. Could be ignition related? Has anyone has this problem and if so is it a easy fix?
