Looks like your expanding your collection, nice! The fuel pump is driven by an impulse line (vacuum) from the engine. After you clean out the tank replace the fuel with some 50:1 mix and prime the lines. Once the air bubble is gone the pump should pull fuel as long as the diaphragm and the impulse Line are good. I would change the fuel filter too. Is power getting to the ignition system? A little off topic but, how is the Shark coming along?
1993 Yamaha WaveBlaster 701
1989 Yamaha WaveJammer 500
