Newbie 95 Seadoo GTX Acceleration issue - Thanks in advance! - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 12-30-2012, 08:30 AM   #1 (permalink)
Unhappy Newbie 95 Seadoo GTX Acceleration issue - Thanks in advance!
Hi there,
I'm new here and am having issues with my 1995 Seadoo GTX 3 seater. I'll try describe the best I can below.
It runs fine and has for some time but when you go full throttle from start it guns and goes to take off with all its might then seems to choke, as though its not getting enough fuel and slowly takes its time to get up on the plane. With more than one rider it doesn't plane at all. Once it gets going, it sometimes revs a little, then dies back down, revs again, dies down. I seem to only be getting half speed at full throttle.
If you pump the primer it goes like a wild horse on fire and rockets away at full speed ahead.
There has been some oil coming out of the rear R.A.V.E valve near the exhaust and I've opened it up and cleaned it and the stems to find the rubber bellows intact and O-rings fine. However the gasket was brittle and broke, and there is a small warp, an almost bubble like bump on the inside of the plastic upper part of the valve just under the red caps (see photos).
Could this be preventing the bellow from operating correctly and messing up my throttle? Could it also be the cause of the oil coming out? The front valve seems fine with no leaks, I'll open it up and clean it as well, replacing any seals needed.
I'm scared to open the carburettor, It looks as though I would have to remove a mountain of other engine parts just to get to the rear carb couldn't be harder than the ton of motorcycles I've worked on though? <famous last words>
I've also read everywhere online about the deathly grey fuel lines? is this true they are just terrible? If so Ouch as my ski still has its original fuel lines in it then... I'll be replacing those...
If I end up tearing this thing apart piece by piece and wish for a good learning curve along the way I will be sure to post a heap of photos of all bits I undertake, including the fuel line replacement for any others in future reference.
I appreciate all and any advice or help. Thanks!
GCPWC is offline   Reply With Quote
Old 02-02-2013, 01:48 PM   #2 (permalink)
I don't think your problem has anything to do with your rave valves. You need to replace the fuel lines and fuel selector switch and rebuild both carbs.
Cliff is offline   Reply With Quote
