you have a bad pressure regulator assy.
It is located on the rear exhaust water box. It regulates the exhaust pressure and if it is bad will cause exactly what you are talking about.
Take it of disassemble clean and reinstall. Sometimes the diaphram will have a hole or other parts inside are faulty. Inspect it carefully and get back to me.
Look in the cooling system schematics and you will see what I am talking about with this link
Check the bellows and exhaust valve for damage. It is most lokely just sticking. Clean and reinstall.
Rivamotorsports.com's Sea Doo PWC Parts Finder
