1994 GTX Died!! Help!!! - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 08-15-2008, 08:29 PM   #1 (permalink)
Default 1994 GTX Died!! Help!!!
I was riding for about three hours with no problems!
And Then!!!
I was moving along with no problem and then engine cut out!!!!
Gas tank 3/4 full!
Selector valve -tried reserve!
Acted as if out of gas!
The only way I was able to get back was moving choke in and out and engine would barely stay running!!!
Start and Stop! Start and Stop! No Power at all move 10ft. cut out!
I recently replaced all grey lines, seafoam in the tank and carbs were rebuilt!
( I do remmeber getting a long, constant,beep noise when starting earlier in the day but it went away- happened twice to come to think of it!)
What could be making this cut out like this!!!???
Possible fuel sender in tank?
I would appreciate any help I can get!
Thanks,
Darren
Darren is offline   Reply With Quote
Old 08-23-2008, 09:51 AM   #2 (permalink)
dooinit in fl's Avatar
Long constant beep is the overheat alarm
94 GTX
00 GSX RFI
04 GTI-LE RFI
99 Yamaha 1200XLT Limited
99 Speedster SK Twin Rotax
Old 08-24-2008, 11:51 AM   #3 (permalink)
Or 12v low. Your battery may not be charging or a clog in the cooling system.
nate_s89 is offline   Reply With Quote
