1995 XP Hull Thru Insert?? - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 08-25-2008, 09:35 AM   #1 (permalink)
Default 1995 XP Hull Thru Insert??
Anyone know how to remove the hull-thru insert so that it can be replaced? My seal carrier bearing seized and twisted of my hull insert. I can't get the remainder of the old one out to put the new one in. In case my terminology is incorrect this is the plastic piece that the drive shaft goes through while exiting the hull.
jaydaniels is offline   Reply With Quote
Old 08-25-2008, 08:29 PM   #2 (permalink)
dooinit in fl's Avatar
Are you talking about the insert inside the hull or the plastic piece under the ski?
94 GTX
00 GSX RFI
04 GTI-LE RFI
99 Yamaha 1200XLT Limited
99 Speedster SK Twin Rotax
Old 08-26-2008, 07:55 AM   #3 (permalink)
This would be the plastic piece inside the hull. It actually has a lip inside the hull and goes through to the underside by the pump. The bearing carrier connects to it inside the hull. Basically it looks like a round piece of PVC pipe.
Old 08-26-2008, 05:15 PM   #4 (permalink)
I usually cut them out and epoxy the new BRASS one back in with two part epoxy.
94 GTX
00 GSX RFI
04 GTI-LE RFI
Old 08-27-2008, 06:39 AM   #5 (permalink)
So the new one is brass? I thought the new one would be the same as the old. That sounds like a better setup. I have the end cut of that sticks out inside the hull but am not sure how to cut the part going through the hull out.
Old 08-30-2008, 02:30 PM   #6 (permalink)
Well, all fxed up. The new insert actually fits inside the old one so it just stays in place. I had to epoxy the new one in. Now I just need to get the thing to start.
Old 08-30-2008, 08:39 PM   #7 (permalink)
Sorry Jay, didnt see your question earlier, but you did it right. Congrats!!! I should have been clearer, what I meant by cut out the old one is, cut the old one flush with the hull.
94 GTX
00 GSX RFI
04 GTI-LE RFI
