97 Sea Doo XP wont start in water - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 09-10-2008, 10:13 PM   #1 (permalink)
Default 97 Sea Doo XP wont start in water
I need a little help. I just purchased a 97 Sea doo Xp. The ski will start on land and idle just fine but when I put it in the water it wont start. It will try to start but will never get going. If I start it on my trailer and keep the engine running I can ride it as long as I'm giving it a little gas. Any ideas???
Lawdawg is offline   Reply With Quote
Old 09-12-2008, 07:01 AM   #2 (permalink)
throttle cable may need to be tightened, as well as the idle set a little bit higher (turn the adjuster slightly to let it rev idle at maybe 50 RPM more. cant really tell exactly, but doesnt hurt to try)
do you have a flush kit? To make sure your getting water to the engine to cool it. Rule of thumb is without a flush kit, dont keep the ski running out of the water for more then 15-20 seconds at a time. (heats up too quick)
Ill keep thinking of ideas on whats going on....
1996 TS 770
mazdaboi is offline   Reply With Quote
Old 09-12-2008, 08:37 AM   #3 (permalink)
Yes I do have a flush kit on it. I will check the throttle cable and bump up the idle and see what happens. THANKS!
Old 09-12-2008, 09:10 PM   #4 (permalink)
dooinit in fl's Avatar
Also check your fuel filters, in the water and the jetpump drawing water a fuel restriction will cause this. Just on a flush kit, the engine is not "under a load" so it is easier to idle.
94 GTX
00 GSX RFI
04 GTI-LE RFI
99 Yamaha 1200XLT Limited
99 Speedster SK Twin Rotax
Old 09-14-2008, 10:03 PM   #5 (permalink)
JUST-IN-TIME's Avatar
is that carbed
if so better rebuild them before a motor blow up
TRUE JACKASS FISHING REPORTS
HUMAN BUILT = HUMAN FIXED
Old 09-16-2008, 05:27 PM   #6 (permalink)
Okay, I replaced all the fuel lines and cleaned the fuel filter. I also bumped the rpm's up. (It was way too low). I also put a fuel additive in just incase the gas was bad. When I put it in the water it started right up and no problems. Thanks guys!!!
Old 09-16-2008, 06:34 PM   #7 (permalink)
Enjoy!!!!!
94 GTX
00 GSX RFI
04 GTI-LE RFI
Old 09-16-2008, 07:24 PM   #8 (permalink)
glad you got it running good!
1996 TS 770
