96 GTX wont crank with spark plugs in it, but cranks with plugs taken out
I just bought a brand new battery and the starter works fine. If the battery is fully charged it turns over for about 10 seconds and then it wont turn any more with the plugs in. With the plugs taken out it will crank forever without any problems. I was thinking that there could be too much compression, but if i put my finger over the spark plug hole with barely any pressure it won't crank. There are some aftermarket parts on it and the person i bought it from told me that the starter is stronger than the stock one, because the stock one doesn't have enough torque to turn it over. Anyone have any idea what the problem may be? thanks
