1994 SeaDoo Bombardier SPX engine size? - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 05-14-2009, 05:53 PM   #1 (permalink)
Default 1994 SeaDoo Bombardier SPX engine size?
I bought this from someone on craigslist and he said the wiring is bad on it. He also said it has a bigger 700cc engine on it, doing some research I only can find SPX's only with the 657cc engine. Is there somewhere on the engine block I can look at that will tell me the difference? That would be the only possible thing I can think of with the wiring being bad, if he swapped engines with another jetski. Otherwise I don't know how the wiring just goes out, without someone messing with it. Any help is much appreciated, I want to try to get this thing running so anxious!
702Mech is offline   Reply With Quote
Old 05-15-2009, 08:02 AM   #2 (permalink)
It should say on top of the magneto box at the front of the engine.
1995 DJ is offline   Reply With Quote
Old 05-16-2009, 03:16 PM   #3 (permalink)
Yes I just found that out. Well the wiring thing makes alittle more sense now that the engine is a 720cc so they tried to swap engines and didnt finish the electrical side of it. Now I have to go pick up a battery and hope for the best, I do have the wiring diagrams so that will help out a lot. Now the next question if I decided to put a different impeller on it should I buy one for the 720cc engine or the 657cc that came stock to fit the hull?
