Originally Posted by sbrown@pittohio
I have the same issue. Rev's no propulsion. I hope I can slide the boot up and all will be well. If not I will go for the propeller being lose. I have no mechanical experience with these things. Thought I found a good deal and so far this ski has been nothing but problems. Bad oil pump, this, some smart aleck put diamond plate for foot pads. I'm too old for this. I just wanted a ski I could tool around on with my kids.
Hey guy, sorry to hear about your luck. As far as can tell it sounds like you need to replace the wear ring, it is a consumable much like a clutch. It is designed to be a sacrificial lamb should should you ingest something into the impeller similar to a cotter pin. It is ceramic when it wears out you just replace it.
See Ya
2009 RXT-IS 255 HP
2008 GTX 215 HP
