I need help with Seadoo piston rings - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 06-05-2009, 07:24 PM   #1 (permalink)
Default I need help with Seadoo piston rings
I did a compression test on my 95 Seadoo gtx 657x, and find the front cylinder has lower compression than the back 80/130. I added a little oil thru the sparkplug hole, restested and the front pressure went back up and both were about even, after a few day I did another compression and the front was back down to 80 again, so after pulling the head off, I find the piston ring is broke, can someone please tell me how to go about changing the piston rings? Can I take the one cylinder case out? I need all the help I can get. Thanks.
My95GTX is offline   Reply With Quote
Old 06-06-2009, 02:11 AM   #2 (permalink)
JayDawg's Avatar
Short of tearing the motor apart and replacing the rings, I don't really know of any other way to fix the problem. Also, why fix just 1 cylinder? Do both since I believe a set of rings comes for both pistons.
1996 Kawasaki 750 SXI
1999 Kawasaki Ultra 150
www.quadsforchrist.net
Old 06-06-2009, 08:18 AM   #3 (permalink)
Thanks JayDawg, after doing a little research and not finding any other way, I do plan on doing both pistons. Next question is - are there any secrets, tips, tricks, or any major things I need to know? This will be my first time (and hopefully last), so any ideas would be so helpful and greatly appreciated, remember I'm a newbie at this whole engine thing.
Old 06-07-2009, 01:03 AM   #4 (permalink)
JayDawg's Avatar
If you are new at doing this sort of thing, I would highly recommend buying an owners manual and following it to the letter.
Old 06-07-2009, 10:24 AM   #5 (permalink)
Thanks again, I have two different manuals and have been pouring over both, seems like it's not too complicated. I was curious if there were any tricks, tips or secrets to this procedure that I should know.
Old 06-17-2009, 09:36 PM   #6 (permalink)
Put tape, rags or whatever to cover up your crankcase when taking pistons off. Circlips are sometimes tough to install, use a very small screwdriver or pick to help. Oil everything. Arrows on pistons point to exhaust side.
Old 06-29-2009, 11:07 AM   #7 (permalink)
Thanks, I got the rings done, no problems. Ran great for a while.
But my problem now is when I run full throttle, after about 8 seconds it bogs down, then picks back up after I stop. I think it's in the fuel diaphragm. After running like this for a half hour (just puttin around) it got progressivly worse, when giving it only 1/4 throttle or so it would bog down to nearly nothing.
Should I get a carb kit or a fuel diaphragm kit?
Not sure what carb I have either. Any help?
Old 07-05-2009, 07:34 AM   #8 (permalink)
Default bogging
try switching the fuel selector switch to reserve it may be dirty lines or filter
rollo450 is offline   Reply With Quote
Old 07-14-2009, 08:28 PM   #9 (permalink)
Yep Rollo, your right.
I bought some black fuel line to replace all the old gray lines thinking this could be the problem, after buying a carb kit and finding it to be okay. The first line to come off went to the fuel selector valve and that was the problem (the valve itself). I couldn't get the screw and the knob off, so cut the lines and bypassed the the whole valve, and she runs like a champ now for as old as she is. This winter is when I'm planning on replacing the lines and replacing that valve. By the way, where can I get one??? And any tips or hints on replacing it, or the rest of the lines?
Thanks.
