1997 Xp Cranking problem with plugs in ,ahhh! - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 06-07-2009, 09:14 PM   #1 (permalink)
Default 1997 Xp Cranking problem with plugs in ,ahhh!
Hello, New here and need some advice. Ive been through 2 starters thinking they were the problem and im stressing out over this. It turns over fine with plugs out but as soon as i put 1 in it just "clunks". Not a power problem as I am using an external 12vdc power source. I poured about a thimble worth of injection oil in cylinders but it did not help. Any help would be appreciated.
spoonman2569 is offline   Reply With Quote
Old 06-17-2009, 09:43 PM   #2 (permalink)
External 12 vdc power source? What about your battery? Usually, it's a weak starter since it has the bendix build right in. You can do a volatage drop test and see which componant is faulty that way. Check all wire connections. A solenoid is pretty cheap too.
Old 06-18-2009, 10:40 PM   #3 (permalink)
Yes I used a my running truck as a power source with jumper cables with good bolted connections straight to the starter. It must be the starter but the crazy thing is I bought a brand new aftermarket one on ebay and it wouldnt work. So then I bought a used one and the same thing. Not solenoid or anything else because Im bypassing all of it. Just wanted some input before I shoveled out $280 for a starter from seadoo.
Old 06-22-2009, 02:44 PM   #4 (permalink)
Check your ground and power wires. If I recall the ground wire bolts under the motor. They like to get nice a cruddy under there.
TriPodRacing is offline   Reply With Quote
