97 GTI will not start. - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 08-08-2009, 10:03 AM   #1 (permalink)
Default 97 GTI will not start.
Has fresh battery. I get the beeps when I connect the key. Hit the start button and nothing. No spin on starter not even the clicking noise. Any thoughts?
THX
JK
oodaes17 is offline   Reply With Quote
Old 08-08-2009, 01:11 PM   #2 (permalink)
THX
JK
Take a test light and ground the clip to the neg. of the battery......then touch the probe to the red wire at the starter.....hit the start button. If it lights up the light, you are getting voltage to the starter, and you will need a new starter or reman. starter.....
You can also do the same thing using a voltmeter......
Neg. to neg on batt......
Pos to red cable at starter....
Measure volts.....
Also using a multimeter check your battery voltage while sitting.......keep the probes in contact with the battery and hit the start button......did the volts drop drastically?
MaddisonCain is offline   Reply With Quote
