Originally Posted by Hoggmech
Trying to help a friend with his 08 GTI 155SE. Manual says to put antifreeze in manifold for outdoor winterization. Manual shows more for the 215 and 255 with the intorcooler. All it shows is the port to do it but says location varies. So I called the dealer which is 5 hours away. They said you had to do it but won't tell me how. Guess they told someone last year and they did it wrong and now there sueing because it froze and cracked. Any help would be great. Thanks
Hey not sure if you still need any help winterizing your ski. But yes you do need to pickle the water intake system with antifreeze. If not you could crack the exhaust, and on supercharged ones the intercooler could freeze and crack in outdoor storage below freezing. After you add fuel stabilizer and fill the tank to prevent condensation, run it on the hose and fog it, then kill it. Next disconnect the water intake line from the rear of the ski. On mine I take off the outlet side of the sea strainer so now then I can insert a funnel. While holding up the funnel and hose pour antifreeze mix 50/50 into the exhaust system until it runs out of the pump nozzle. Bam your done. This also will get into the intercooler on supercarged models. Spray the externals with an anticorrsion spray, remove the battery for charging and cover it up. Then put the $125.00 the dealers charge in your pocket
2009 RXT-IS 255 HP
2008 GTX 215 HP
