1992 SP Engine does not turn - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
post #1 of 14 (permalink) Old 07-16-2016, 07:48 PM Thread Starter
Hi I just bought a very clean 1992 Seadoo xp with a stuck engine or jet drive. I know it has been sitting for along time and the guy I got it from said it was the jet drive. I am new to working on waverunners and was wondering if someone could point me in the right direction for separating the engine from the drive shaft to see if the engine is good.
chrisorbics is offline
post #2 of 14 (permalink) Old 07-17-2016, 08:02 AM
Garage
There are only two ways to accomplish this. Pull the engine, or pull the jet pump.
Actually, you can remove the engine mount bolts and slide it forward also, but you will have to disconnect the exhaust also.
rodsatheart is online now
post #3 of 14 (permalink) Old 07-17-2016, 09:17 AM Thread Starter
What is the best way to do this?
Ok I would like to pull the jet pump. What is the best way to accomplish this?
post #4 of 14 (permalink) Old 07-17-2016, 09:42 AM Thread Starter
I am trying to find a service manual. Does anyone know where I can find one online?
post #5 of 14 (permalink) Old 07-18-2016, 05:36 AM
Garage
Ebay is going to be your best bet. Get a book, not cd.
post #6 of 14 (permalink) Old 07-18-2016, 10:14 AM Thread Starter
I just found one online but I won't let me post the link since i'm so new to the forum. I will post it later
post #7 of 14 (permalink) Old 07-18-2016, 11:26 AM Thread Starter
The plot thickens
So I made a puller out of a 2x4, yes wood. It worked great. Man that pump was glued on there. It is off and the plastic wear ring is all messed up but I can figure that out I believe...
BUT IT GETS BETTER...After pulling the jet pump and the long shaft out I pulled the spark plugs and turned the engine by hand at the flywheel. It felt very very good until I rotated it alittle further and it locked. I turned it the opposite way and the same thing, 1/2 rotation and locked almost like something was in the engine. Odd. It was about to get worse. Upon putting the plugs back in and trying to rotate it again the whole cylinder assembly lifted off from the bottom end. WHAT THE... someone has been in here. Looks like they tore the engine down thinking the problem was the engine but it was actually the jet drive. There was a small allen head bolt in the engine. Cylinders lifted up because the bolts had been loosened but I would have never noticed that because the head was put back on.
So the cylinder bores are very good still at standard 76mm. I will hone them out because there is slight rust in one spot. The pistons are scuffed so since I'm doing all this work I will replace them and obviously all of the gaskets and o rings. When I pulled the cylinder all of the water and junk that was in there went into the rear cylinder crank area so I'm going to pull that and turn it upside down, flush, and oil the heck out of it.
I am going to try and get the jet drive apart and get some pictures on here.
post #8 of 14 (permalink) Old 07-18-2016, 11:42 AM Thread Starter
Pictures before I took it apart but after I washed it.
Here is one
post #9 of 14 (permalink) Old 07-18-2016, 11:49 AM Thread Starter
Pics
more pics comming
ID:	9418   Click image for larger version
post #10 of 14 (permalink) Old 07-18-2016, 11:53 AM Thread Starter
Pics
vintage seadoo lol.
ID:	9434   Click image for larger version
ID:	9442   Click image for larger version
ID:	9450   Click image for larger version
ID:	9458   Click image for larger version
Human Verification
