1995 gts pump problem - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
post #1 of 7 (permalink) Old 04-18-2017, 06:50 AM Thread Starter
I have a 1995 GTS with the single carb white 580/587 in it. The previous owner said that it normally went 42ish mph for them. I was only able to get it up to 32mph with severe cavitation. I pulled the pump and saw that the wear ring had excessive clearance between the impeller. i was torn whether I was going to get the impeller refurbished of not but then I noticed some of the vanes were busted behind the impeller. Is this a big deal?
ID:	11266   Click image for larger version
ID:	11274   Click image for larger version
ID:	11282   Click image for larger version
nerraw117 is offline
post #2 of 7 (permalink) Old 04-18-2017, 10:38 AM
Garage
I would just replace the pump and get a stainless solas impeller.
rodsatheart is online now
post #3 of 7 (permalink) Old 04-18-2017, 10:39 AM Thread Starter
any recommendations on the pump replacement? the one from sbt?
post #4 of 7 (permalink) Old 04-18-2017, 10:47 AM
Garage
You can, but you can also find good ussd pumps on ebay. Just find out what others it fits and include that in the search.
post #5 of 7 (permalink) Old 04-18-2017, 10:52 AM
Garage
Check with impros. They might be able to get you a pump and set it up with a new impeller so all you will have to do is bolt it in.
post #6 of 7 (permalink) Old 04-18-2017, 01:19 PM Thread Starter
would a plastic pump work to replace the aluminum one? the plastic ones do seem much thicker.
post #7 of 7 (permalink) Old 04-18-2017, 08:04 PM
Garage
Normally they are either stainless steel or a composit material. You need to replace it with the same material that is already there. If the new ring is not the same od it qill either not fit or put the impeller in a bind where is wrinkles. You might be able to find a pump with a composit ring that will fit yours. Those rings are much easier to change.
Human Verification
