Originally Posted by Outlaw
Let me ask if the plugs look rich (wet and black), or lean (gray and dry). Because the higher the elevation the leaner the jet because of less oxygen. So unless your plugs are burning lean jetting up won't help. I used to drag race two stroke snowmobiles in the mountains where not only elevation is a factor but weather as well using an oxygen density meter.
I looked at the plug and it had oil on it however the center part was a nice mocha brown. When I jet my quads the mocha brown color lets me know it is running perfectly. I have not looked at the plugs that I used down at Englebright (500 feet) yet.
I am thinking that because of the elevation change it is running lean in the lower elevation because of the thicker air it is starving of fuel. In the higher elevation the air/fuel ratio is better.
My question do I need to jet it differently for the lower or is there something like a air/fuel adjustment screw I can mess with?
