my daughter ran her 95 seadoo gts out of gas this past weekend. she killed the battery trying to restart. i have recharged the battery and now when i try to start it it only makes a click sound and will not turn over. any help would be great
it sounds like the starter may be bad since the battery was run down trying to start it. make sure the engine will turn free with the plugs out. put a dvm on the starter wire and hit the button, if it shows 12 volts then the battery cable is loose or the starter is bad.
