1995 XP - No spark but turns over - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 08-13-2010, 07:30 PM   #1 (permalink)
Default 1995 XP - No spark but turns over
I have replaced spark plugs and checked fuses. MPEM looks brand new (no water has gotten in). Have used a fully charged battery.
Can anyone help me on the next step to determine the issue?
Thanks!
KCMiller3 is offline   Reply With Quote
Old 08-14-2010, 11:54 AM   #2 (permalink)
Bump...
Also, the gauges are not functioning (before or after lanyard is attached), but the ignition lanyard button and start/stop button are both functioning.
Any ideas?
Old 09-07-2010, 10:56 PM   #3 (permalink)
check and double check all your grounds. Electrical and water dont get along to well lol. After you've checked your grounds you can try a few other things, first cut off about 1/4'' on the plug wire at the boot and reattach the boot and recheck. If still no succes start looking at the coil. If your coil has a white wire on it pull the white wire off and install a test light and crank the motor. If it lights up, you have power going to the coil just not out. Start with the cheapies first ( replace complete plug wires ) if that doesnt work your probably going to be looking at a coil. If the test light doesnt come on start looking at wiring/stator or possibly an MPEM. Just because it "looks" new doesnt mean its working. Hope this helps!
97gsxguy is offline   Reply With Quote
