Originally Posted by Watson91
Hello,
I just recently became the owner of a 95 GTX. My plan is to convert it over to pre-mix. I was wondering though what type of oil I needed to use. The manual says use nothing but Bombardier Rotax Injection Oil, but seems to be off the market now.
Could I use something like SeaDoo XPS oil or Amsoil INTERCEPTOR 2-Cycle Oil? What would you recommend?
Thanks,
Alex
Any two stroke oil that is rated at TCW-3 should do the job. Bombardier still makes two stroke snowmobiles so they do have a two stoke oil for you ski. Though it is expensive.
You may need to carry spare plugs when you convert over. Now you will be running 50:1 at an idle instead of 100:1. Which will foul plugs at idle to long.
The whole idea with oil injection is that it meters the amount of oil at different rpms, which in turn uses less oil and is better for air quality.
50:1 is a ratio for full throttle.
Also it will smoke more at start up.
2009 RXT-IS 255 HP
2008 GTX 215 HP
