seadoo rod end diameter question
I recently purchased a bottom end off ebay and the seller said it was from a Seadoo 580, but the rod end diameter was a lot larger than the original. The bearing and piston pin is too small. Is this a 720 crank? Something different. The rest of the crank looked similar. Was there a different bearing that was larger to fill the space?
