97 GTS Questions - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 09-19-2010, 09:47 PM   #1 (permalink)
Default 97 GTS Questions
I got my wife a 97 GTS at the beginning of this season and we both really love it.
But we have some questions.
First, it seems to go through gas really fast, as if it has a small tank. We have to switch it to reserve really quick and we have to fill it frequently. We take the seat off and eyeball the tank to make sure we get it full.
The most we have ever been able put in it is 5 gallons, including today after someone syphoned our gas out this week.
Could it be that small a tank?
I like to do preventative maintenance on our stuff. What exactly should I do, and how often?
How about winter? We are on Table Rock Lake in Southern Missouri, which does not freeze. We keep our boat (outboard) on alift in our dock all winter.
TIA
JLB1 is offline   Reply With Quote
Old 09-20-2010, 06:45 AM   #2 (permalink)
Outlaw's Avatar
Talking
TIA
Ok, yes your tank is smaller then new skis. Reason being your ski burns less fuel then skis like mine. Your fuel tank including reserve is 12.6 gallons. My skis hold about 16 gallons. You should get 4 -6 hours of running depending on how fast you run it.
Most important thing to keep an eye on is your oil injection pump, that is what could cook the motor if not working ok. Make sure you top it off each time to evaluate how much oil it is using. Check oil lines for signs of hardening, cracking or slipping off. Even though you are probably in fresh water you should flush out the system after each use. Flushing it out on the lift or trailer also gives you a chance to check in the engine compartment to see if things look good. This as long as you know how to run the water, in a nut shell, never have the water going thru the motor when it is not running. After you disconnect the water goose the motor once or twice to blow out the water. Then spray some CRC 666 anti-corrosion spray on everything.
For winterizing you need to add STABIL to the gas and run it so stablized fuel reaches the carbs, while spraying fogging oil into the carbs to coat the cylinders. Then remove the battery for winter storage and charging.
In the spring remove your carb and clean it.
2009 RXT-IS 255 HP
2008 GTX 215 HP
Old 09-20-2010, 07:59 AM   #3 (permalink)
Thanks.
Yeah, I was figuring 12 gals, but wondering why we have to run it on reserve so quick and why 5 gals tops it off when it stops running on reserve. I have not been able to find fuel consumption figures like are available for boats. Our fuel gauge does not work, so we eyeball the tank.
How much should it be using?
Probably can't flush it out after every use. No fresh water on dock.
How about stuff like plugs and fuel filter.
Old 09-20-2010, 08:01 AM   #4 (permalink)
2009 RXT-IS 255 HP
2008 GTX 215 HP
29 ' Outlaw 850 HP
& how much gas do you use?
Old 11-06-2010, 09:53 AM   #5 (permalink)
For winter, can we just leave it on the lift? Our lake does not freeze, but we do get freezing temps.
We left our '88 Yamaha on the lift last winter and we leave our boat on the lift.
Old 11-14-2010, 12:31 PM   #6 (permalink)
Anyone? . . .
Old 11-16-2010, 04:07 PM   #7 (permalink)
Outlaw's Avatar
Talking
I use alot of gas if I run hard. I am surprised at how little gas I use in my Riva Stage III RXT if I am running at 35 MPH. You should be ok with leaving it on the lift as long as you have winterized it properly and remove the battery to trickle charge over the winter. I would however wrap it in a heavy duty plastic tarp over your summer cover.
2009 RXT-IS 255 HP
2008 GTX 215 HP
Old 11-16-2010, 04:35 PM   #8 (permalink)
Thanks . .
