96 gsx cranking problems
Hello all, new to this forum but have used lots of info found from other threads. Went to winterize my 96 gsx. It turned over a few times, then wouldn't crank. Checked battery, ok. Must be solonoid, jumped it, and same thing. starter engages but would not turn over motor. Pulled plugs, motor turns over just fine. Must be starter, had it rebuilt and re-installed, same thing. Pulled plugs and verified motor is not binding by spinning output shaft. What am I missing?
no one has any ideas?
Can I put a meter on the starter to check the output? Sound possible that the starter rebuild could have been bad?
What would you do next if it were your ski?
