Update: Spoke to a tech who said the plugs may be bad, Pulled them and they had a thick film of oil around the compression seal. I will install new plugs tonight and update on weather or not it solved the problem. The tech said sometimes when it sits for a long period like mine did "6 months" on initial startup the cylinders may have an influx of oil that fouls the plugs.
