95XP Restoration Project - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 04-13-2011, 01:02 PM   #1 (permalink)
Default 95XP Restoration Project
Hello everyone. I just got back 2 95XP's that I sold to a guy 10 years ago. Most of that time they have been sitting. One has a bad motor and the other one ran when it was parked. I have a factory Sea-doo replacement motor for the one and swapping out the engines isn't an issue yet. My question is this. Has anyone had any luck freeing up stuck cables? And if not, does anyone recommend a supplier of them? Also going to need some carb kits. Any suggestions would be appreciated.
droid is offline   Reply With Quote
Old 04-15-2011, 08:57 PM   #2 (permalink)
Let me know how it goes... I just got me a 95 & 96 Xp myself.
Big Boi is offline   Reply With Quote
Old 04-20-2011, 11:54 AM   #3 (permalink)
Hey Big Boi,
Looks like we have similar projects. You definitely need to get a battery so you can check stuff out. Got 2 new batteries with mine. Like the other guy said take the plugs out and see if you can turn the motor. Take the flywheel shield off and turn the motor by hand using the flywheel. If it turns then hit the starter to make sure it is working. If all that is working, check the compression with a compression gauge. I'm sure you'll have to take the carbs off and atleast clean them, if not rebuild them. Mine were gummed up solid but I soaked them in a bowl of carb cleaner and they freed right up. Haven't had much time to mess with mine yet but I'll let you know how the progress goes. Good luck with them.
Old 04-20-2011, 11:43 PM   #4 (permalink)
Built a dolly for one ski today. Im hoping to start working on them after the holiday. Any progress with yours?
