96 gsx no power rev problem
Hi i have a 96 seadoo gsx with the 800 motor. the problem that i am having is that out of the water it runs fine but in the water if you pinn it it will barley rev above idle, but if you keep it pinned and feather it it will finaly get power and take off un till you let off for a couple of seconds????I have changed all the grey fule lines cleaned the carbs and rave valves checked the compression in both cylinders and they both check out fine, any ideas?? Thnx
