95 XP - Getting gas, spark, and compression wont fire... now what?
I had problems with my XP bogging out 2 summers ago; not starting, etc... I rebuilt the carbs (& rejetted to correct pop-off), replaced gas lines, snipped the plug wires, replaced baffle... Got it on the lake once that summer to fine tune (Thank for all your help PWC members).
Last summer I took it out twice... it was screaming! Then on a long weekend by the 3rd day it started bogging out again, hard starting, and then wouldn't fire any longer. I parked it for the winter.
I finally got around to looking at it. I am getting good spark (w/new plugs), good compression, and fuel. I am using a new battery. The engine is turning over, it just won’t fire at all... not even the slightest hint as if it is getting no spark.
If I have fuel in the cylinder and good spark, shouldn’t I get something? Could I be getting too much fuel? I was hoping to not have to tear into the carbs again, but seems that may be what is needed... what should I be looking for?
This thing is awesome when running... which is becoming not very often… but motivation enough to keep trying!
