Trim question - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 07-10-2011, 08:41 PM   #1 (permalink)
Default Trim question
I have a 1995 seadoo xp. It has the trim but I don't think it works. When I push the button, should I hear the motor? My first outing on it I had a passenger and the bottom was very low unless I was going a decent speed. How can I tell if its bad and is there anyway to level it out manually and just not worry sbout fixing it?
shevie is offline   Reply With Quote
Old 07-10-2011, 08:55 PM   #2 (permalink)
How fast were you going? I'm by no means an expert but I've never ridden a jet ski (especially with 2 people) that wasn't low in the water until you reach a certain speed - most will sit partially 'under' the water (especially with 2 people) until you get going pretty fast, then they plane across the top of the water.
Crackofdawn is offline   Reply With Quote
Old 07-10-2011, 09:00 PM   #3 (permalink)
Once we planed out it was fine. long as that's normal I'm good. You know smudging about the working of the trim system?
Old 07-10-2011, 10:00 PM   #4 (permalink)
I'll let someone else chime in if there is anything else you should know - I don't know hardly anything about it - the trim system on my 97 Seadoo doesn't work but I also have a jet ski without a trim system and they both ride the same at low speeds and plane the same, so I figure it must be pretty normal
Old 07-10-2011, 10:44 PM   #5 (permalink)
Thanks for the input!!
