The fuel pump is in the carb. But if you are pulling gas from another container then your problem is in the line between the filter and the tank. Check your fuel filter and selector for stopages. You"ll have to pull it out and clean it or at least blow through it. Also need to pull the lines that go into the tank and check for debris. It would be a good idea to replace these now as well if you havent already. SOmetimes there is a strainer on the pickup lin in the tank. Be sure it is clear. All this assume you have good gas in the tank.
