I'm assuming you have power and it turns over and all. Have you tested the plug wires, coil, CDI, Wiring. Those old seadoo didn't have a mpem like the newer models all the electrical that has to do with firing is in a box mounted on top of the battery in front of the motor and gets its power from the stator in the housing on the front of the motor and from the battery. I have about 10 or so of those old style electrical boxes and stators if you figure out what you need and can't find it elsewhere.
