2002 sea-doo bombardier gtx 4-tec drive shaft not spinning
Hey guys,
Just got the jet ski not to long ago it was running great and then the wear ring went out not a big deal u know i put it in and bolted everything back on and then something went out in the computer the cpu was the one that works with the drive or ignition cpu because the guys at the shop had to re-register the key. But my question is the new problem i put it in the water and it wouldn't go move nothing and then over heated or i got the *hi temp* sign. but i took it out disassembled the impeller and housing and started it up and gave it a little gas and the drive shaft wasn't spinning or anything what happened does anyone know? it was running fine before the cpu and the wear ring. ps the guy at the shop had to pump like 3or 4 quarts of oil to get water out of engine tipped and sucked in water. can anyone help thank you in advance
