96 xp problem - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 07-24-2011, 01:12 AM   #1 (permalink)
Question 96 xp problem
Hey guys i have a 96 seadoo xp with the 800 moter i have a problem with the ski when i take it to the lake it starts up really hard like almost uses the whole battery to start it and then after i get it started i can
Floor it and it goes just has fast as idle and it will slowly start to get a little more speed almost like its surging up to full throtle and finally after its at full throtle it will go but if i slow down it does it agian and if i stop same thing all over agian so today i put it on the trailer and started it up and gave it gas and the rpms went right up and was like nothing was wrong so i shut it off and tryed agian and now wont start and somtimes when im out there it will be ok at low rpms but it still is a little slow and ill go up for a tailstand stand in not even straight up and it will lose all power an not go untill level agian and then do the bog thing agian i just replaced the fuel lines and rebuilt the garbs im stuck thanks for any help
96SEADOO XP is offline   Reply With Quote
Old 07-25-2011, 07:57 AM   #2 (permalink)
seadoobutch787's Avatar
Do a compression check first. Did you clean out your fuel selector switch when you did the fuel lines?
A motor will rev up like nothing is wrong when it's on a trailer and no load is applied to the motor even if it has low compression.
96 Seadoo XP limited mod
96 Seadoo GSX build coming this winter!!
seadoobutch787 is offline   Reply With Quote
