HELP! 1999 SeaDoo GS
Had this boat for a couple of months. Bought it, a 1999 GSX, and a 1997 XP. The XP was a little rough, and figured it would be my "project" and I'd ride the the others. The GS was the first troublemaker. Rebuilt the carb, and it was the most reliable of any of them. Have not replaced fuel lines yet. Daughter and I went out last weekend and had a great time on XP and GS. However, on the way back to the ramp, the GS shut down. Typical loss of power, then died. Fouled plugs, no big deal. Took it, and the GSX out last night, and my daughter didn't put the drain plugs in. Didn't drain the bilge, figured it would empty when we taxied out. Wrong, the motor took on water. Brought back home, pumped out the cylinders, got it running like a champ again. Decided to bypass the oil injection and mix the fuel to cut down on the plug fouling issue (50:1, 40 oz to 15 gallons of no ethanol fuel). Took it out tonight, daughter idled out of the no wake, and it died before, we got out. Brought it in, and the bilge was full again. All the fuses were fine, so no reason to think the bilge pump wasn't working (other than a full bilge). Drained the bilge, pumped the cylinders, got it screaming again. Put back in the water, same bilge issue, but this time the engine compartment filled with smoke. Concerned that water isn't pumping though the exhaust, and it fried it?!?! Brought it home and haven't done anything to it yet, however, now the I think about it, I probably need to pump the cylinders again. First issue though is why I'm not expressing water out of the bilge. No gaping holes in the hull or anything. HELP!
