Get a compression test done, it will give you some idea of the wear on the cylinders linings, SEADOO manual should have the new compressions for the engine from the factory to compare them with. Low compression dont bother with it, check the spark plugs to see if they are burning cleanly, start the engine for 30 seconds, give a quick rev to 4500 rpm a couple of times, see if there is any oil smoke or smell of oil in the fumes - pretty easy to detect. Remember, the ROTAX is like a 4 stroke car engine, as long as its been well maintained and because it doesnt ingest salt water, it theoritically should last well into the 1000's of hours.
